01-15-2004 09:09 AM - edited 07-04-2021 09:17 AM
Members,
Any suggestions as to which is the best WLAN management application to use for AP 1200s?
Our WLAN Network is small at the moment but could grow a lot bigger.
I would like to try Cisco Wireless LAN solution Engine, but unfortunately they do not make available an evaluation copy.
So, any ideas?
Martin.
01-15-2004 10:26 AM
Martin,
I am aware of a solution that effeciently manages, moitors and helps in mass-configuration of small and medium sized WLAN infrastructure including all Cisco Accesspoints, Switches and routers.
If you are interested send me an e-mail at prvengalam@yahoo.com. I can refer you to the appropriate contact. They do provide an evaluation copy.
Praveen V.
01-16-2004 02:11 AM
"but could grow a lot bigger!";
then Cisco Wireless LAN Solution Engine is the right Solution for sure. (near 5000 USD)
An evaluation copy is impossible because you need a "special" cisco hardware. (Cisco Unix "Server", 1HE). Try to get a testing equipment if possible.
hardware:WLSE 1130
software: Version 2.5
Arno
