02-10-2011 03:36 PM - edited 07-03-2021 07:48 PM
Hello:
I have a WCS 4400 system and run 3 seperate WLANs: 2 WPA secured networks and 1 open, using LDAP authentication.
Is it possible to schedule, or script, one of these WLANs to automatically disable at 8am and enable at 2pm each day?
I'm sorry if this has been asked and answered before, I tried searching the KB and google for quite some time, but to no avail. Thanks VERY much to anyone who is able to help in this!
Solved! Go to Solution.
02-11-2011 09:24 AM
http://www.cisco.com/en/US/docs/wireless/wcs/6.0/configuration/guide/6_0ctrlcfg.html#wpmkr1113392
Let me know. I don't have WCS yet, and It'll take me a few days to setup a 30 day demo to test it out myself.
02-10-2011 08:02 PM
Strangely enough, I was tasked with the same project today as well. Please post back if you find anything.
02-11-2011 07:30 AM
Michael,
If I find out how to do this I will send you the solution right away! If you happen to find the solution first please send it my way. Thanks!
02-10-2011 08:11 PM
You have several ways of doing this ...
1. WCS will allow scheduled enable/disable of radios;
2. Active Directory
02-11-2011 07:28 AM
Thank you for your reply, I appreciate it! Unfortunately I'm not sure how to implement this.
I see an option in WCS for Scheduling a start time for a WLAN, but no option for a stop time. Or is there a correcsponding CLI command that does this?
As far as using active directory to implement the scheduled enable/disable I know WCS is linked to my AD through LDAP to allow user control, but I don't know how to use AD to control login times. Can you give me any pointers on how to do this, or point me in the direction of the appropriate manual.
Thanks again for the help so far!
02-11-2011 09:24 AM
02-11-2011 09:40 AM
Well I'll be! Thats it! You sir are officially, as my students would say, the man!
