WLAN Controller
keynet
Hello
We have updated our DHCP Server from windows 2003 to windows 2008 r2. Our problem is now that we do not get an ip address from our dhcp server for wlan clients. Clients with cable get address from the same dhcp server and scope.
Thank you for your help.
Kind regards,
Alex Vonarburg
5 Replies 5
Surendra BG
The clients are in What state??
Surendra
Surendra BG
dhcp.
Alex
Thanks for the update!!
I assume that its in DHCP required state.. Are we able t oping the DHCP servre ip address fro mthe WLC??
Surendra
Surendra BG
patoberli
This Setup works absolutely fine here.
Did something else change? Maybe the ip address of the DHCP server?
Can you sniff the packets on a client and check if you get any DHCP reply at all?
pato
Vinay Sharma
Level 7
Level 7
Hi Daniel,
Please mark the Question as Answered, if the provided information is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Thanks & Regards
