WLC 4400 and multiple authentication servers e.g. RADIUS, ACS
minoaht
Can the WCL 4400 be set up to use multiple RADIUS servers? The user accounts for accessing wireless would use a RADIUS server. The administrative accounts for the WLC would reside on an ACS server.
Jagdeep Gambhir
Level 10
Level 10
Can this be done in Cisco ACS v3.3 without NAP?
rcullum
ACS is a radius server, as well as TACACS+. The WLC can be set up to use one radius server for user auth, and another for WLC admin auth.
Yes, that is correct. You can set acs to use both radius and tacacs.
For this you need to add WLC twice in acs-->network configuration. But you need to keep host name different.
eg 1) Host name WLC --->IP x.x.x.x -->Auth using -->radius
2) Host name WLC1--->IP x.x.x.x --->Auth using -->Tacacs.
You need to set up tacacs commands on WLC along with radius commands.
~JG
Please rate helpful posts
