Highlighted
Beginner
WLC 4400- Guest Access
Hi Guys,
I have a query , I understand the web authentication flow as explained in the below doc.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml,
Its talking about to have a DNS server to be configured and this DNS ip will be allocated along with the DHCP response
So can I have Public DNS directly assigned for the Guest users ? and I dont use a dedicated DNS for the Guest userr
if possible where should be it configured in the WLC
Thanks in Advance
3 ACCEPTED SOLUTIONS
Highlighted
In the VIP (Virtual Interface).  The link I posted should have that information.  If your not purchasing a certificate, you don't need to worry about DNS as the users will get a certificate error.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Highlighted
Agree with Scott
Add....
you can enter DNS here:
Highlighted
On the controller handling the guest traffic .. If you anchor your guest to an anchor controller then this is where it gents configured. Not the internal (foreign controller)
8 REPLIES 8
Highlighted
Hall of Fame Master
If you plan on using a 3rd party certificate to eliminate the certificate error, you need to be able to add a DNS entry for the FQDN of the certificate to the VIP of the WLC. Using a public DNS, you will not be able to unless you can add an entry in the public domain space. So if you have a registered domain and can add alias to one of your public address, you can eliminate the certificate error. The thing you have to do is change your VIP to that of one of your public address and then when you create your CSR for your certificate, you add a DNS entry that resolves the FQDN to the VIP.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080a77592.shtml
-Scott
Highlighted
Thanks Scott for the response
I just one of your previous post
https://supportforums.cisco.com/thread/2127632
So it is possible to put the public DNS . I dont have certificate authentication
Where will be the option to add the DNS detials in the WLC
Highlighted
Scott
-Scott
Highlighted
Agree with Scott
Add....
Highlighted
Gotcha... Thanks  again guys,
So I should add this DNS entry in Guest controller and the internal WLC right ?
Highlighted
Highlighted
Thanks all :
Let me implement this and will update here
Highlighted
Hi Guys
Today I tried this implemenation : but result falied
On the guest controler I entered the public DNS ip addresss
After adding it , it requested need to restar the sytem to take it in effect.
my DHCP is on a server - under the DHCP pool I pointed the DNS is public DNS
Result
I was getting an ip address , and DNS also shows the public in the ipconfig /all out put
But the webportal was getting redirected to my public DNS ip address in stead of 1.1.1.1
Any idea , what could have went wrong.
I am not sure if we have to configure on the internal controllers as well under the virtual interface
