05-13-2008 06:45 AM - edited 07-03-2021 03:51 PM
I'm with a problem in my WLC 4402. When I reboot the chassi the Distribution port 1 dont't come work, it's has a status Down.
I had change the WLC and SFP GLC-T, but the problem come to appear.
Anyone know whay this happen??
Thanks..
João Ferreira.
05-18-2008 04:25 PM
I had exactely the same problem!!
I found out that it only works when plugged into a Gig port. A normal 100Mb port doesn't work for some reason.
05-18-2008 06:23 PM
I'm using the DS port in the interface Gigabitethernet but the problem persist.
So i had change the chassi but the problem appear again.
05-18-2008 08:34 PM
what model switch are you using?
05-19-2008 11:23 AM
The Switch that i'm used is 4507R and interfaces there is a module Gigabitethernet WS-X4548-GB-RJ45.
05-19-2008 02:59 PM
So if you plug the same switch port into the service port of the WLC it comes up?
If you log in via the brower and click on Controller then Ports is the Admin status 'enable' for the distribution port?
05-20-2008 04:31 AM
when i access the controller via webpage acesso by service port that is connected in the the same switch module interface. In the monitor page the port shown (Green) Status: LINK UP. But the cable is disconnected.
I think that is the problem. Because the interface had to be with the status: DISABLE.
You understand. Did you see any think seemed.
thanks.
05-20-2008 09:54 PM
So you're saying with the cable disconnected from the port, it is showing as Green from the webpage? That doesn't sound good at all, maybe even a bug. What version of software are you running. I've got 4.2.61.0.
My problem that I had is different to what you're experiencing now.
