04-10-2013 01:47 AM - edited 07-03-2021 11:53 PM
Hi all,
i am getting an error during the Upload of Login page for WLC 5508 customized.
After the upload is completed i receveid the error "Error extracting webauth files."
I tried to create the file *.tar with different program (winrar, 7zip, gnu tar, etc)
anyone know the solution for this problem?
Marco
Solved! Go to Solution.
05-17-2013 08:29 PM
I use PowerArchiver and once in a while 7-zip.
04-10-2013 03:14 AM
Solved. Tar issue
05-17-2013 08:12 PM
Hi, May i know what program you use to solve the issue?
05-17-2013 08:29 PM
04-03-2015 12:20 AM
Hi, same problem and same tool/method have been tried out/applied but still doesn't work for me. any other option should i look into? my controller is 5508 running 7.4.100.0...
04-03-2015 12:33 AM
hi,
be sure to create TAR file of (login.html+folder CSS) and not TAR file of login folder.
04-05-2015 07:22 PM
TQVVM Marco, it helps and issue resolved. I was downloading a folder consists of (login.html+folder CSS) compressed .TAR but failed. Instead of putting in a folder and directly downloaded the compressed .TAR and it was extracted successfully.
Thanks.
01-30-2017 08:39 AM
im having a similar issue, its letting me uplaod a .tar of just login.html but it errors when i create a .tar file with an image in as well.
02-01-2017 01:49 AM
The maximum size of all the files should be lower than 1MB for the controller to extract it.
09-25-2015 12:56 AM
I can upload to WLC by use 7zip (Windows 7 32bit)
Note - WLC version 7.6.130.30
01-27-2017 01:44 AM
I had the same issue. Problem for me was, that i used a multilangual version that had:
login_DE.html
login_FR.html
login_IT.html
...and so on. As soon as i created an empty login.html and logout.html, unpacking was successful. Used 7zip to create the tar file wihtout the use of folders. Working with vWLC 8.3.102
01-27-2017 05:41 AM
Best is to use Unix program (example: Cygwin Terminal- is free software that provides a Unix-like environment ) to create a tar file (even it will work with the diff login_IT/login.Fr or login.DE.html names...)
