wlc 5508 layer2 security
How can we enable layer 2 security (DAI,DHCP SNOOPING ...etc) on our wireless network?
Our wlc is 5508
You need to implement those feature in your switch network for wireless vlans if you really required these features.
This will give you an basic understanding of how DHCP snooping works
http://mrncciew.com/2012/12/27/understanding-dhcp-snooping/
I would suggest you to read "configuration guide" of the switch platform you are using to see more details of these two feature.
Rasika
**** Pls rate all useful responses ****
Hi  Manannalage,
thanks for your reply.
but the problem is that the connection between WLC and the switch is TRUNK and allowed all wireless vlans ( almost 30 vlans) so any DHCP offer and REQUEST will be allowed as it's the trust interface !
P.s the SW acts like DHCP server.
Just a point.
Check this doc, it may hlep you:http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/emob73dg/emob73/ch4_Secu.html
Allo only required VLANs on WLC connected port on Switch.
Example:
interface FastEthernet0/41
***description Cisco WLC ***
switchport trunk allowed vlan 5,8-10
switchport mode trunk
no shutdown
Dont forget to rate helpful posts
