04-19-2019 12:04 PM - edited 07-05-2021 10:16 AM
Hi all,
I've problem with a WLC 5520. few Clients an IP 0.0.0.0.
Software Version is 8.5.140.0
Around 30% are not OK.
The problem is, we are testing on our secondary wlc all AP are moving in Secondary WLC perfectly but the few client that don't get a IP address or stuck in 0.0.0.0 until we restart the AP, after restart the AP the all clients get a ip from dhcp.
We are not using DHCP in this WLAN and DHCP is not configured in the wifi profile as well as in the controller advanced settings.
Right now , The clients are connected correctly, but they got a disconnect sometimes, which we can not clarify at the moment.
04-21-2019 01:55 PM
Its N+1 (two controllers) but not completely HA because one wlc is another location or second one is other .
mobilty between two controllers is establish in my case???
if this is mobility issue why this issue suffers few clients not all clients????
04-22-2019 07:16 AM
04-22-2019 01:08 PM
further , im testing with your response mobilty is must configured in flex connect central switching,
once mobilty configured then im moving Ap's from one controller to another but im little bit confused, right know im stable in one controller and im facing the issue again client obtain ip adress 0.0.0.0. may be this is not the issue of mobilty group because all ap in one controller or the client response is same.
04-23-2019 07:23 AM
04-19-2019 06:22 PM
Like what said, this is N+1?
1. Check that allowed VLANs are the same;
2. Make sure the dynamic VLAN IP address, subnetmask, gateway and DHCP are all the same.
04-19-2019 07:54 PM
Yeah, its N+1 onmy two controller, all ap are in FlexConnect mode, each FlexConnect group have different vlan and differnt dhcp poorl for users.
04-19-2019 09:57 PM
04-19-2019 10:44 PM
Ssid need to be sane subnet? Please elaborate
04-20-2019 01:52 AM
04-20-2019 05:21 AM
Didn’t get your point,
where i can implement layer 3 roaming?
04-20-2019 06:53 AM
04-20-2019 07:49 AM
In my case both flexconnect local switching and vlan based central switching box is unchecked
09-26-2019 03:13 PM
Did you resolve this- getting something similar: It takes an AP reboot for client to get a DHCP address , this is random, Some clients are connected yu have blue light on AP and others won't get the DHCP though they pass through ISE (AAA) with AnyConnect NAM : centralized auth . All APs they are in FlexConnect mode , with local switching. Code version 8.5.135.0,
09-27-2019 01:41 AM
09-27-2019 02:23 AM
I assume you are meaning 8.5.140.0 or 8.5.151.0. Those have a possible fix ? Will read the release notes.
