05-22-2019 10:38 AM - edited 07-05-2021 10:27 AM
We are kinda puzzled by this as we just retired our WISM2 for the 8540's and it has been pretty flawless. we did not roll the config from the old to the new as we didn't want any legacy bits (buttons) pushed that we weren't aware of..
Notes:
* Equipment is all in the same vlan as before ... solarwinds, Prime, WLC
* WLC shows the AVC working ..can ealsy pick a client(s) and see the applications etc..
* WLC Software Version 8.5.140.0
Our WISM'2 did netflow to our Solarwinds just fine but now nothing arrives from the 8540?
We have run WISM's since they first came out ...we are puzzled
05-22-2019 06:56 PM
Did you check you have configured "Netflow Exporter" & "Netflow Monitor" correctly on 8540. Also WLAN is configured with AVC profile ?
See below post that I tested sometime back
https://mrncciew.com/2018/02/20/wlc-netflow-with-extrahop/
Rasika
*** Pls rate all useful responses ***
05-29-2019 04:58 AM
as you WiSM and Soilarwinds are operating for some time,
Check if your Solarwinds version is compatible with the netflow version of the 8540?
05-29-2019 05:11 AM
found this remark on Solarwinds
Note: Only one exporter can be added in the WLC
Note: Only one Monitor entry can be added in the WLC
Check you do not allready have configured netflow to send to Cisco Prime
05-29-2019 05:49 AM
Yeap, we have beside myself three others that have yrs of WLC experience.. at this point it appear the flows are not exiting the 8540 according to Wireshark ... traps and syslog arrives on Prime with no problems
Thx
JM
05-29-2019 09:38 AM
If it is a 8540-HA setup, do a fail-over & see if that makes any difference.
Rasika
