108
Highlighted
Beginner
WLC 9800 Prime Infrastructure Partial Collection Failure
Hi all
Prime 3.5 does not show APs and Clients of WLC9800. Inventory Status shows "Partial Collection Failure".
On the WLC I noticed that Telemetry connection is stuck in "Connecting".
Does someone know how to fix this?
Urs
3 REPLIES 3
VIP Engager
Re: WLC 9800 Prime Infrastructure Partial Collection Failure
Do you have all updates, most importantly Device Packs, installed?
It should be supported in 3.5, but might require a patch.
Beginner
As far as I know there is an additional update available.
The following versions are installed:
PI 3.5 Update 02
Prime Infrastructure 3.5 Device Pack 3
Cisco IOS XE Software, Version 16.11.01b
VIP Engager
I suggest you upgrade to Update 03, because it fixes a lot of critical security issues:
https://www.cisco.com/web/software/284272933/145488/PI_3_5_Update_03_Release_Note.pdf
But otherwise the version looks fine and I think the 9800 should be supported by DP3. I suggest you open a TAC. On the other hand, the 9800 is probably newer than 3.5 and could not be fully implemented.
Based on, for example, this bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj68855 it should show the APs on a 9800 WLC in PI 3.5, although it is buggy.
I haven't checked all the known issues, you might find something here: https://bst.cloudapps.cisco.com/bugsearch/search?kw=infrastructure%209800&pf=prdNm&sb=anfr
[Edit]
It seems 3.6 is of no real help either: https://community.cisco.com/t5/wireless-security-and-network/no-aps-seen-in-cisco-prime-infrastructure-3-6-with-wlc-9800-cl/m-p/3874275
