06-18-2019 04:02 AM - edited 07-05-2021 10:34 AM
Hi all
Prime 3.5 does not show APs and Clients of WLC9800. Inventory Status shows "Partial Collection Failure".
On the WLC I noticed that Telemetry connection is stuck in "Connecting".
Does someone know how to fix this?
Urs
06-18-2019 06:52 AM
06-18-2019 07:05 AM
As far as I know there is an additional update available.
The following versions are installed:
PI 3.5 Update 02
Prime Infrastructure 3.5 Device Pack 3
Cisco IOS XE Software, Version 16.11.01b
06-19-2019 08:00 AM - edited 06-19-2019 08:01 AM
I suggest you upgrade to Update 03, because it fixes a lot of critical security issues:
https://www.cisco.com/web/software/284272933/145488/PI_3_5_Update_03_Release_Note.pdf
But otherwise the version looks fine and I think the 9800 should be supported by DP3. I suggest you open a TAC. On the other hand, the 9800 is probably newer than 3.5 and could not be fully implemented.
Based on, for example, this bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj68855 it should show the APs on a 9800 WLC in PI 3.5, although it is buggy.
I haven't checked all the known issues, you might find something here: https://bst.cloudapps.cisco.com/bugsearch/search?kw=infrastructure%209800&pf=prdNm&sb=anfr
[Edit]
It seems 3.6 is of no real help either: https://community.cisco.com/t5/wireless-security-and-network/no-aps-seen-in-cisco-prime-infrastructure-3-6-with-wlc-9800-cl/m-p/3874275
10-07-2019 11:46 AM
I've got the same issue with WLC 9800 version 16.11.1b and PI 3.5 with these updates:
PI 3.5.1 Maintenance Release (PI_3_5_1-1.0.22.ubf)
Device Pack 3 (Device-Pack-3-PI3.5-08.ubf)
Did Update 03 fix the issue?
If yes, how can I find this update? I don't see it published at the Cisco Software Dowload site.
10-07-2019 11:51 AM
10-11-2019 05:22 AM
Thanks for the quick response. We'll try with DP4 and post the result.
10-14-2019 07:03 AM
Same result with DP4. After a discovery, all AP's appear as "Unreachable" with this failure reason:
Device: <IP address> is ping reachable. Got snmp timeout when querying system table from the device.
10-14-2019 07:41 AM
10-21-2019 02:43 AM
Thanks patoberli for your response.
The WLC model is a virtual C9800-CL, that is supposed to be supported by PI 3.5. Anyway, I was planning the upgrade to PI 3.7 when I found this document:
It says that for IOS-XE 16.11.1b only PI 3.6 is compatible, and if we upgrade to PI 3.7 then we have to go to IOS-XE 16.12.1 on the WLC. I'll schedule the upgrade with the customer, and update when done.
02-05-2020 01:53 AM
The upgrade of both (PI and WLC) solved the issue:
PI --> 3.7
C9800-CL --> IOS-XE 16.12.1
02-17-2020 08:12 AM
Thank you for the resolution feedback!
I too am facing a similar issue, with a lab 9800-L, running 16.12.2s code, that cannot be fully-discovered and managed by Prime running 3.7. The 9800 keeps coming up in Prime 3.7 as "Un-Managed" (although Reachable). I don't want to downgrade the 9800-L to 16.12.1, as that might lose it's ability to recognize the new Catalyst 9130ax AP's. Any ideas? I'm considering some kind of debugs that might reveal if Prime is having difficulty with SSH, or with SNMP when it logs into the 9800-L. Hoping for resolution, always considering misconfig on the 9800-L (brand new for us) as a possibility. Thanks.
04-20-2020 02:28 PM
9800-CL works via netconf-yang, I applied it as an explanation of the link and it worked:
validation:
Prime_Infrastructure# ssh <9800_ip_address> <priv15_username> port 830
