1174
Highlighted
WLC and access point help!
So I bought a 2504 AP. I also have some AIR-CAP3602I-A-K9.
The WLC web interface sees them in the CDP neighbors. The devices get an ip address but I can't add them as access points. I think if I can do that I can get something simple going.
On the access points I get the stuff below.
I didn't set it? At least not the
CISCO-CAPWAP-CONTROLLER
I'll be honest I've never set one of these up and I'm on a steep learning curve!
Thanks !
% Invalid input detected at '^' marker.
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:50.167: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.33.0.75,                      mask 255.255.255.0, hostname APfc99.47c8.518a
Translating "CISCO-CAPWAP-CONTROLLER.lan.andrew.priv"...domain server (192.168.2.234)
*Mar  1 00:01:06.039: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP. (192.168.1                     .29)
*Mar  1 00:01:42.039: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.lan.andrew.p                     riv
*Mar  1 00:01:42.039: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_ac:d1:c2'running                      version 7.0.220.0 is rejected.
*Mar  1 00:01:42.039: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:42.039: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 s                     tate 2.
*Mar  1 00:01:42.039: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controll                     er
*Mar  1 00:01:42.039: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.3                     3.0.100
*Mar  1 00:02:14.039: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_ac:d1:c2'running                      version 7.0.220.0 is rejected.
*Mar  1 00:02:14.039: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:14.039: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 s                     tate 2.
*Mar  1 00:02:14.039: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controll                     er
*Mar  1 00:02:14.039: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.3                     3.0.100
*Mar  1 00:02:46.039: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_ac:d1:c2'running version 7.0.220.0 is rejected.
*Mar  1 00:02:46.039: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:46.039: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:02:46.039: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:02:46.039: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.33.0.100
Not in Bound state.
*Mar  1 00:03:04.039: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:03:11.055: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:03:11.079: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.33.0.75, mask 255.255.255.0, hostname APfc99.47c8.518a
*Mar  1 00:03:20.039: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP. (192.168.1.29)
*Mar  1 00:03:56.039: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.lan.andrew.priv
*Mar  1 00:03:56.039: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_ac:d1:c2'running version 7.0.220.0 is rejected.
*Mar  1 00:03:56.039: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:03:56.039: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:03:56.039: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:03:56.039: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.33.0.100
*Mar  1 00:04:28.039: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_ac:d1:c2'running version 7.0.220.0 is rejected.
*Mar  1 00:04:28.039: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:04:28.039: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:04:28.039: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:04:28.039: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.33.0.100
6 REPLIES 6
Hall of Fame Master
Re: WLC and access point help!
You need to run 7.3 or newer on the WLC to support that AP 3600.
-Scott
Hall of Fame Master
Here is a compatibility matrix that explains the support for various device.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
-Scott
Thanks for your help again. Are you saying an older access point will work? Do they have to be physically plugged in or can they go over the vlan? To get the upgrade is going to take a few days even with cdw correct?
Hall of Fame Master
I don't understand. If you look at the matrix, that will explain what AP's support what code on the WLC. In order for the AP to join, the AP needs to have connectivity to the WLC. You can do this by putting the WLC and AP on the same subnet or use option 43 or dns.
-Scott
Hall of Fame Master
Is a CDW engineer doing the work?
-Scott
Hall of Fame Master
Content for Community-Ad
August's Community Spotlight Awards
