01-11-2014 07:24 AM - edited 07-04-2021 11:56 PM
I'm able to backup WLC configs to the localdisk using TFTP
I'm able to backup WLC configs to the localdisk using FTP
However, when I try to back WLC configs to an FTP server not local to Prime the backups fail (I don't have the exact/vague error MSG in front of me)
My question is simply this:: Can it be done? I've just never tried.....
Solved! Go to Solution.
01-12-2014 11:17 AM
Do I need to install that also? Is that why I'm not able to check for updates and have to upload the file manually?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
01-12-2014 11:30 AM
That December patch comes up as October in PI. You can see I uploaded the 2.0-3 from CCO is December, But the file date is for the ubf is 11/11/2013 and PI reports it as October also?
Scott
01-12-2014 11:33 AM
By the way... tested it out on a 5508 SNMPv3 running v7.6.100.0 and worked fine.
Scott
01-12-2014 11:30 AM
No worries Rob, Try it in your lab set up & let us know if it doesn't work, may be some other issue
Rasika
01-13-2014 04:42 PM
a different lab box i used today (other than my lab VM) worked fine backing up WLC configs to a remote FTP server
as usual:::: "thanks guys for the response!"
