02-14-2020 04:58 AM - edited 07-05-2021 11:43 AM
hi guys
please can anybody advise how to list a configuration of AP which get disconnected from WLC point of view? Usually I am listing configuration of particular AP using the way: "Wireless" -> Access points -> All APs -> use filter/select for specific AP to get the configuration.
but this list shows only APs which are registered to WLC. I would like to see config of AP which is now disconnected, but was configured on this WLC before. how can I do that?
controllers: 5520, 5508,2504,WS-SVC-WISM2-K9
SW version: 8.5.135.0
thanks
Solved! Go to Solution.
02-14-2020 05:43 AM
WLC does not show this. WLC only shows live Access Points.
This requires Cisco Prime.
-If I helped you somehow, please, rate it as useful.-
02-14-2020 05:43 AM
02-14-2020 06:00 AM
Hi Flavio
thanks for response, right, I can see them in PI. but anyway it is strange that I cant see config details for AP which definitely has its own record created in WLC directly from WLC.
02-14-2020 06:31 AM
Capwap tunnel is what allows the WLC to pull information from Access Point, if the tunnel is down, there´s no way to get this information. As the WLC does not stores does config fot futher consult, you lost those information as soon as the tunnel goes down.
That´s why Cisco Prime is so important, in my opinion.
02-14-2020 07:29 AM
if the AP configuration is not stored locally, then your explanation completely makes sense. I thought it is stored locally (fixed IP, AP group, flexconnect group, ...). thank you Flavio for your time spent on this topic :)
