WLC show configuration
egeorgopoulos
I would like to know whether there is any command that shows the configuration of the wireless controller (5508) like when you upload the configuration file from the GUI of the WLC. In other words, I don't want to show me all the verbose running configuration as the "show running-config", but a brief configuration as for example described below:
config time timezone location 13
config time ntp interval 43200
config time ntp server 1 10.x.x.x
config advanced 802.11b channel add 1
config advanced 802.11b channel add 6
config advanced 802.11b channel add 11
config advanced 802.11a channel add 36
config advanced 802.11a channel add 40
config advanced 802.11a channel add 44
config advanced 802.11a channel add 48
config advanced 802.11a channel add 52
config advanced 802.11a channel add 56
config advanced 802.11a channel add 60
config advanced 802.11a channel add 64
config certificate generate webadmin
config interface address management 10.x.x.x 255.255.255.0 10.x.x.x
config interface port management 1 2
config interface dhcp management primary 10.x.x.x secondary 10.x.x.x
config interface
continues
Thank you in advance.
Scott Fella
I believe the show tech support command has this information.
Sent from my iPhone
-Scott
Scott Fella
Sent from my iPhone
-Scott
tfraij
hello
please try
show run-config commands
or show running-config commands
Kind regrads
Talal
please rate answers that you find useful , and mark as answered - when it is :-) - so others can find it easily
