344
Highlighted
Beginner
WLC SNMP Error 604
I have just deployed an HA deployment of Prime Infrastructure 3.4 and are running the latest patches and device packs.
I have just tried to discover my WLC'c via SNMP v3 but I keep getting SNMP Sync Error. I have checked and double checked the settings on the WLC with the Credential profile and they are correct.
I have debugged this on the WLC and I can see the traffic getting to the WLC but I get this error.
Packet from: *IP OF PRIME SERVER*:49730, in_packet_len = 137
*SNMPTask: Apr 02 16:42:41.928: [PA] SNMPD: Failed to build SnmpMessage error code = 604
*SNMPTask: Apr 02 16:42:41.928: [PA] SNMPD: *NOT* sending out packet, out_packet_len = 0
I have tried SNMP 2c and this works fine without a problem. I cannot just use 2c though as it violates security policy.
Does anyone know what this could be? WLC's are 5520's running 8.5.140.0
Everyone's tags (3)
3 REPLIES 3
Rising star
Re: WLC SNMP Error 604
  = There have been numerous reports concerning Prime's snmp v3 capabilities in the past. If it all works with SNMP Manager software quering a controller with v3, then Prime is to blame.
 M.
Beginner
Hi Marce,
I would tend to agree with that. SNMP Manager software? Which software is this, can you point me in the right direction of this?
I may have to open a TAC Case.
Ryan
Beginner
I have managed to get this resolved.
Although, I'm not too sure what the actual issue was.
I setup both controllers in P.I for SNMP v2c and discovered them, I then deleted them, modified the credential profile for SNMP v3 and discovered again and this has seemed to work.
I have since disabled SNMP v2c and re-synced the controllers and they are still connected. Fingers crossed for this. It seems to P.I issue here. I did use the SNMP tester tool from Paessler to verify SNMP v3 was working.
Thanks for the advice guys.
Content for Community-Ad
August's Community Spotlight Awards
