Highlighted
Beginner
WLC webconsole permissions and ACS.
Is it possible to limit what users are able to do and view in the webconsole of a WLC 5508 via ACS. I have ACS setup to restrict what commands can be run depending on user on the CLI however when they log into the webconsole they can access everything?
2 REPLIES 2
Highlighted
You need to define custom tacacs+ service on your ACS and then define the Role for each user or group of users that identify the forms they should access only. The following link contains everything you need:
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60sol.html#wp1697872
one more thing , Roles are case sensetive make sure to copy and paste as mentioned above
Please Make sure to rate correct answers
Highlighted
Thanks Dehnee,
Actually I rated your reply with 2 rather than 5 and it can not be changed
I hope that the originator will mark your answer as the correct answer.
Amjad
Rating useful replies is more useful than saying "Thank you"
Content for Community-Ad
