01-07-2015 11:10 PM - edited 07-05-2021 02:13 AM
Hi Support,
We are using Cisco WLC 2504 (version 7.3.101.0). We tried to authentication our local management user to cisco secure ACS 5.4 but failed. Please suggest us how can we deploy it.
Thanks in advance.
01-07-2015 11:23 PM
Sounds like you are trying to deploy tacacs with 5.4 ?
Here os a video ..
http://www.labminutes.com/sec0089_acs_tacacs_device_admin_wlc
02-15-2015 10:30 PM
Within the greater context of two major AAA protocols—RADIUS and TACACS+—ACS provides the following basic areas of functionality:
ACS supports multiple RADIUS-based authentication methods that includes PAP, CHAP, MSCHAPv1, MSCHAPv2. It also supports many members of the EAP family of protocols, such as EAP-MD5, LEAP, PEAP, EAP-FAST, and EAP-TLS.
In association with PEAP or EAP-FAST, ACS also supports EAP-MSCHAPv2, EAP-GTC, and EAP-TLS. For more information on authentication methods, see Authentication in ACS 5.4.
ACS is the point in your network that identifies users and devices that try to connect to your network. This identity establishment can occur directly by using the ACS internal identity repository for local user authentication or by using external identity repositories.
For example, ACS can use Active Directory as an external identity repository, to authenticate a user to grant the user access to the network. For more information about creating identities and supported identity services, see Chapter8, “Managing Users and Identity Stores”
ACS provides advanced monitoring, reporting, and troubleshooting tools that help you administer and manage your ACS deployments. For more information on the monitoring, reporting, and troubleshooting capabilities of ACS, see Chapter 11, “Monitoring and Reporting in ACS”.
For more information about using ACS for device administration and network access scenarios, see Chapter4, “Common Scenarios Using ACS”
02-18-2015 01:03 PM
Authentication of Management Users on Wireless LAN Controller (WLC) Configuration
