WLC with RADIUS Server Authentication and EAP-TLS
jacinto1m
Can the 2504 WLC be configured to work with one RADIUS Server for Authentication of Management Users and with a second server for 802.1x EAP-TLS certificate authentication for the end users.
In summary:
Management Users will authenticate on RADIUS Server 1
Wireless End users will request 802.1x EAP-TLS authentication certificate from AAA server 2
Thanks in advance.
Scott Fella
Duplicate... Don't know why:)
Here is an example of where you define the roles.
-Scott
5 Replies 5
Scott Fella
Yes that can be done. For manager you can check the radius server which is for management only. For wireless, it's the same but you only check network user.
-Scott
Scott Fella
-Scott
Scott Fella
-Scott
Thanks Scott!
So you can have 2 Radius Servers, one for the management users and a 2nd one for the Network users correct?
Yes that is correct.
-Scott
