Highlighted
VIP Advocate
WLSE 2.13, a [ in password causes an Error 500
Hi All
I detected that a [ (and probably other signs) create an Error 500 in the WLSE if entered in the password field of a configuration template.
This error probably also happens with other fields and other sites.
The whole error message:
Error: 500
Internal Servlet Error:
javax.servlet.ServletException: String index out of range: -56
at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:459)
at wlse.configure.soap._0002fwlse_0002fconfigure_0002fsoap_0002fconfig_0005fpreview_0002ejspconfig_0005fpreview_jsp_0._jspService(_0002fwlse_0002fconfigure_0002fsoap_0002fconfig_0005fpreview_0002ejspconfig_0005fpreview_jsp_0.java:1743)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:119)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.apache.jasper.servlet.JspServlet$JspCountedServlet.service(JspServlet.java:130)
at org.apache.jasper.servlet.JspServlet$JspServletWrapper.service(JspServlet.java:282)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:429)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:500)
at org.apache.tomcat.core.ServletWrapper.doService(ServletWrapper.java:405)
at org.apache.tomcat.core.Handler.service(Handler.java:287)
at org.apache.tomcat.core.ServletWrapper.service(ServletWrapper.java:372)
at org.apache.tomcat.core.ContextManager.internalService(ContextManager.java:797)
at org.apache.tomcat.core.ContextManager.service(ContextManager.java:743)
at org.apache.tomcat.service.connector.Ajp12ConnectionHandler.processConnection(Ajp12ConnectionHandler.java:166)
at org.apache.tomcat.service.TcpWorkerThread.runIt(PoolTcpEndpoint.java:416)
at org.apache.tomcat.util.ThreadPool$ControlRunnable.run(ThreadPool.java:501)
at java.lang.Thread.run(Unknown Source)
Root cause:
java.lang.StringIndexOutOfBoundsException: String index out of range: -56
at java.lang.String.substring(Unknown Source)
at com.cisco.nm.wlse.config.CliCommand.(CliCommand.java:44)
at com.cisco.nm.wlse.config.CliCommand.getCliCommands(CliCommand.java:225)
at wlse.configure.soap._0002fwlse_0002fconfigure_0002fsoap_0002fconfig_0005fpreview_0002ejspconfig_0005fpreview_jsp_0._jspService(_0002fwlse_0002fconfigure_0002fsoap_0002fconfig_0005fpreview_0002ejspconfig_0005fpreview_jsp_0.java:1684)
As this sign is accepted on the Access Points itself, it should also be possible to enter it in the WLSE.
Patrick
4 REPLIES 4
Highlighted
Collaborator
If you use the Custom Value section of the template to push the same command, does it also give the same Error 500?
Highlighted
Yes the same error happens then.
Patrick
Highlighted
Beginner
There is a BUG [CSCse66673] in 2.13 release which says -
WLSE 2.13 IOS Config Template shows Error 500 in Preview page.
No Workaround.
Sushil
Highlighted
Thanks Sushil!
Pato
Content for Community-Ad
