06-29-2006 06:51 AM - edited 07-04-2021 12:32 PM
Hi All
I detected that a [ (and probably other signs) create an Error 500 in the WLSE if entered in the password field of a configuration template.
This error probably also happens with other fields and other sites.
The whole error message:
Error: 500
Internal Servlet Error:
javax.servlet.ServletException: String index out of range: -56
at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:459)
at wlse.configure.soap._0002fwlse_0002fconfigure_0002fsoap_0002fconfig_0005fpreview_0002ejspconfig_0005fpreview_jsp_0._jspService(_0002fwlse_0002fconfigure_0002fsoap_0002fconfig_0005fpreview_0002ejspconfig_0005fpreview_jsp_0.java:1743)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:119)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.apache.jasper.servlet.JspServlet$JspCountedServlet.service(JspServlet.java:130)
at org.apache.jasper.servlet.JspServlet$JspServletWrapper.service(JspServlet.java:282)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:429)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:500)
at org.apache.tomcat.core.ServletWrapper.doService(ServletWrapper.java:405)
at org.apache.tomcat.core.Handler.service(Handler.java:287)
at org.apache.tomcat.core.ServletWrapper.service(ServletWrapper.java:372)
at org.apache.tomcat.core.ContextManager.internalService(ContextManager.java:797)
at org.apache.tomcat.core.ContextManager.service(ContextManager.java:743)
at org.apache.tomcat.service.connector.Ajp12ConnectionHandler.processConnection(Ajp12ConnectionHandler.java:166)
at org.apache.tomcat.service.TcpWorkerThread.runIt(PoolTcpEndpoint.java:416)
at org.apache.tomcat.util.ThreadPool$ControlRunnable.run(ThreadPool.java:501)
at java.lang.Thread.run(Unknown Source)
Root cause:
java.lang.StringIndexOutOfBoundsException: String index out of range: -56
at java.lang.String.substring(Unknown Source)
at com.cisco.nm.wlse.config.CliCommand.(CliCommand.java:44)
at com.cisco.nm.wlse.config.CliCommand.getCliCommands(CliCommand.java:225)
at wlse.configure.soap._0002fwlse_0002fconfigure_0002fsoap_0002fconfig_0005fpreview_0002ejspconfig_0005fpreview_jsp_0._jspService(_0002fwlse_0002fconfigure_0002fsoap_0002fconfig_0005fpreview_0002ejspconfig_0005fpreview_jsp_0.java:1684)
As this sign is accepted on the Access Points itself, it should also be possible to enter it in the WLSE.
Patrick
06-29-2006 04:22 PM
If you use the Custom Value section of the template to push the same command, does it also give the same Error 500?
06-29-2006 10:10 PM
Yes the same error happens then.
Patrick
08-02-2006 07:31 PM
There is a BUG [CSCse66673] in 2.13 release which says -
WLSE 2.13 IOS Config Template shows Error 500 in Preview page.
No Workaround.
Sushil
08-02-2006 09:19 PM
Thanks Sushil!
Pato
