WLSE - how to delete unused IP segments
omrh
Is there any possibility how to delete unused segmentts from WLSE db?
More specific info(answer to subsidiary Cisco Expert Question below)
At 1st we had a WiFi locality - e.g. 10.1.97.0/29 is management seg. WLSE discover it.
Now we physically uninstall locality/HW but IP segment is still in WLSE db => WLSE generate still unaccessible/fault messages in periodic cycle.
It's incorrect by me. It is motivation to delete taht IP segm. from WLSE db.
Message was edited by: omrh
sschmidt
Can you ask the question a different way?  I'm not quite sure what you mean by unused IP segments in WLSE?
My answer is upwards, I modified my original answer.
sschmidt
You can go to Devices > Discover and search by IP address.  Use a wildcard for  IP range.  You will be presented with the devices that were in that range.  From there you can delete the decommissioned devices which should stop the fault messages.
