WLSE to WDS Authentication Status shows Unauthenticated
Scott Fella
I have around 15 Sites with individual WDS AP's that show up int the WLSE as KeysSetUpWithWDS. However, I have around 10 sites that the WLSE to WDS Authentication Status shows Unauthenticated. Is there a certain amount of WDS AP's that the WLSE can handle. Each site has a primary WDS and a secondary WDS. The sites that the primary WDS is authenticated with the WLSE, the primary shows Unauthenticated.. which I guess is normal. What am I missing here that some are authenticated and some are not. Thanks!
-Scott
5 Replies 5
rmushtaq
Level 8
Level 8
Are you using CiscoSecure ACS or local radius server for WDS authentication?
There is a primary and secondary WDS at each site and a ACS in the data center that authenticates all the users.
-Scott
What version of CiscoSecure ACS are you using?
It is v3.3. There is a total of 28 sites and 10 which I get thet error.
-Scott
Hello
please check CSCsb47726
best regards
oliver
