WLSM - Redundancy/Support for AP1300
DAVID MYERS
Hi Jeremy,
I have a requirement to deploy a WLSM as part of site wide wireless project. The particular requirement is for layer 3 roaming. Should I be looking to deploy a pair of WLSM/s (in separate 6500 chassis) for resilience? If so, how is redundancy supported e.g Active/Active in a load sharing capacity or Active/Standby for failover? If the latter is supported - is stateful failover also supported?
Can you also advise when the AP1300's will be supported by the WLSM.
Dave
fmeetz
Level 4
Level 4
The design considerations are explained in this document,
http://www.cisco.com/univercd/cc/td/doc/product/wireless/wlsmdig.htm#wp36479
