Workgroup Bridge only probing.
bouvot_julien
It's my first post so I hope I won't forget important details
I try to configure a WorkGroupBridge AP (Cisco 1240) with a LW-AP connected to a WL Controller 4400.
My situation looks like to this one : http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080905cea.shtml
The only thing I have to modify is the authentication encryption.
Below, the WLAN parameters.
Unfortunately and despite of many docs I've found on Cisco website, I don't understand the authentication error I have between WGB and AP.
A debugging on WLC give an infinite result of this error :
*Dec 13 13:24:08.798: 58:8d:09:8e:28:dc Scheduling deletion of Mobile Station:  (callerId: 24) in 5 seconds
*Dec 13 13:24:08.851: 58:8d:09:8e:28:dc Scheduling deletion of Mobile Station:  (callerId: 24) in 5 seconds
On the controller, the AP State is on "Probing" status.
On the WGB I just have this error :
%DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: WPAIE Invalid unicast suite count: 2
Can you help me to resolve this problem?
So, this is the conf I have configured :
____________________________________________________________________________________________________
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 <Password>
clock timezone GMT+1 1
ip subnet-zero
no aaa new-model
dot11 ssid <Wifi SSID>
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa
   authentication client username <username> password 7 <encrypted password>
   infrastructure-ssid
dot11 network-map
power inline negotiation prestandard source
username Cisco password 7 <Encrypted Password>
username cat-tacacs privilege 15 password 7 <Encrypted Password>
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid <Wifi SSID>
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role workgroup-bridge
rts threshold 2312
mobile station period 20 threshold 70
beacon period 50
infrastructure-client
bridge-group 1
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
no dfs band block
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
sntp server <SNTP Server address>
end
Looking forward to hearing from you,
J.B
6 Replies 6
George Stefanick
on your wlc under your WLAN do you have aironet extensions check boxed ?
George Stefanick
What security are you using on your wlc ?
Yes, "Aironet extensions" are checked
What Security? A Radius accounting with TACACS+ for local logging.
I see on the bridge you have WPA / TKIP and on your controller you have WPA/WPA2 and AES and TKIP.
hav you tried just allowing WPA / TKIP on your WLC.
Yes, I tried... No changes.
My advice at this point since its still just in probe state.. Rip the wgb back to basic meaning no security and then start to apply pieces of your Config and test as you go along.
