WPA2 minimum passphrase length
jarod.alley
Software version:Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(10b)JA1, RELEASE SOFTWARE (fc2)
For some reason it will not allow me to set a passphrase to anything less than 15 characters. WPA2 should allow for 8 characters or more. Anyone else have this problem or know the solution?
Did you try like this:(Dont use 7)
dot11 ssid XXXX
authentication open
authentication key-management wpa version 2
wpa-psk ascii cisco123
wpa-psk ascii 7 XXXXXXXXXXXXXXXXXXXXXXXX
Dont forget to arte helpful posts
Sandeep Choudhary
shortest password allowed with WPA2 is 8 characters long and it must work. You must be doing something in config.
Could you paste the AP config here.
Dont forget to rate helpful posts
Thanks for the follow up. I've attached the config. Let me know what you think. Nothing jumps out at me.
dot11 ssid XXXX
authentication open
