AIR-CAP702i - Set to Autonomous Mode
djohnson
Pre-Sales support advised that the 702i will operate as a stand alone AP in autonomous mode.  When I purchased the device it came with instruction for setting up the device but only in a controller based configuration.  I see the mode button on the device but the documentation says it will do a factory reset for only Autonomous mode AP's.
I called for support but the support rep said the device does not qualify for technical support, only hardware support or replacement.  I find it hard to believe Cisco is selling a product but not providing documentation on how to fully configure the device and then saying over the phone they will not help with a configuration questions.
How do I get the device into Autonomous mode?
Eric Moyers
Level 7
Level 7
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I am sorry to hear that you are experiencing this issue.
I am very sorry for the disconnect between you and the Presales Rep that you spoke with. The CAP702I is, as you have found out, truly controller based. I am not sure, but I feel that maybe the Sales Rep was referring to the SAP720i, the difference be as I am sure that you can tell is the C and the S one meaning Controller and the other Stand Alone. I hope that this clears up the misunderstanding. I would check with the vendor you purchased it from, they should be willing to swap it out for you.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
Moin Ilyas
Level 4
Level 4
Please refer:
https://supportforums.cisco.com/discussion/12382041/air-cap702i-e-k9-autonomous-ios-problem
