10-31-2012 12:35 PM
I have configured two AP541N in a cluster, but only VAP0, is listed as clustered. None of the VAPs seems to be clustered. What can I configure to get all SSIDs clustered?
Product Identifier: | AP541N-E-K9 |
Hardware Version: | V01 |
Software Version: | AP541N-K9-2.0(4) |
Thanks!
10-31-2012 01:23 PM
Hello Eskild, can you please verify the VAP is enabled and broadcasting?
-Tom
Please rate helpful posts
10-31-2012 01:43 PM
All VAPs are enabled and broadcasting.
Only VAP0 is listed as "In Cluster" under "Cluster -> Wireless Neighborhood".
Thanks!
10-31-2012 01:54 PM
Are all SSID broadcasting when you use your wireless connection manager from the computer? When you configure one of the AP541 and successfully join the cluster, all settings should mirror to all other AP. If you make a change to 1 unit, all units are updated with those changes.
Can you verify the cluster is fully intact with the correct cluster names, etc?
Here is an example of the Wireless Neighborhood
-Tom
10-31-2012 02:04 PM
Hi Eskild
Yep Tom as usual is spot on, the AP uses a proprietary protocol within the default vlan to communicate with other AP's.
But do please check out the admin guide built into the Access point, in this case it could explain how clustering is configured and what it does..
Goto the cluster tab and select help at the top right hand corner. You should see, a complete description on what clustering does, what needs to be configured so that APs in the same copper IP network can communicate between themselves and form a cluster. A section is copied below just as a reference..
The AP cluster is a dynamic, configuration-aware group of APs in the same subnet of a network. Each cluster can have up to 10 members. The cluster provides a single point of administration and enables you to view the deployment of access points as a single wireless network rather than a series of separate wireless devices. A network subnet can have multiple clusters. Clusters can share various configuration information, such as VAP settings and QoS queue parameters.
A cluster can be formed between two APs if the following conditions are met:
The APs use the same radio mode (for example, radio 1 uses 802.11g)
The APs are connected on the same bridged segment.
The APs joining the cluster have the same Cluster Name.
Clustering mode is enabled on both APs.
regards Dave
10-31-2012 02:26 PM
As far as I can see, the cluster is properly configured. Config changes is distributed to both access points:
As you can see in the image, only the SSID "skaar", is listed as "In cluster".
Thanks!
10-31-2012 02:46 PM
Notice the VAP names. The blue bars indicate it detects the SSID and of course the mbps. Take notice at the top of the screen is the mac address and IP address of the cluster node. Also notice there is a "repeat" of SSID.
skaar 192.168.123.4 is 46 mbps
skaar 192.168.123.7 is 45 mbps
observe the duplicate entries
KLHEIA53
SKLABV6
GJESTER
Right below this is the same SSID but on opposite AP. Observe how each of those SSID correspond to each different AP IP/mac address
-Tom
10-31-2012 02:54 PM
Thanks Tom,
I have seen the things you asked me to look at, but nothing explaines why the following entries are not listed as in cluster:
- KLHEIA53
- SKLABV6
- GJESTER
skaar is listed as in cluster as so should the other SSIDs. The way it looks now, is that the three enries above are SSIDs in two none clustered access points.
Thanks.
10-31-2012 02:59 PM
Are the SSID configured on your AP or you have no idea what those are? Notice the picture and red marks. You can choose to view what details. The AP will show other AP in range of the cluster.
- KLHEIA53
- SKLABV6
- GJESTER
-Tom
10-31-2012 03:02 PM
They are SSIDs that I have configured:
10-31-2012 03:04 PM
Okay, now please make a screen shot of your cluster neighborhood using the option "in cluster". Please show the entire page as my above example
-Tom
10-31-2012 03:07 PM
10-31-2012 03:12 PM
Thanks, please choose option "in cluster" and make similar screen shot.
-Tom
10-31-2012 03:14 PM
10-31-2012 03:21 PM
What happens if you put your other ssid in to vlan 1?
-Tom
