Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello all,A while ago I purchased a Cisco WAP121 for dedicated use by my two 802.11n laptops only, hoping to enjoy maximum speed for transferring files etc. All other devices use an older 802.11b/g access point. I live in a remote area so there are n...
When trying to upload rootfs.bin file found in .tar archive, progress bar moves to about 70%, then process is stopped with the"Firmware upgrade has failed. Please ensure that valid entries were specified in the required fields"message.Can anybody hel...
hi,I've been trying to get a Cisco WAP321 working with Radius authentication with a Windows 2008R2 Active Diretory server and I cna't make it work.The etries in the WAP log are very vague:Sep 25 2012 11:57:52 info hostapd[6247] wlan0: IEEE 802.11 ...
Hello,I was discussing the WAP321's roaming in this thread https://supportforums.cisco.com/thread/2192532?tstart=0 but wanted to move the discussion to wether I should use 2.4ghz or 5ghz.It's a real shame that this device does not support dual band b...
I want to create one more SSID (for guest use) in WAP321 AP. Is it possible to perform such setup with non-cisco switch and firewall. Please advise. Thanks !
I've been playing with the RV110W and Internet Access Restrictions by MAC for about 2 weeks. During this time, I've done everything I can think of and have read everything I can find to get this feature to work... to no avail.I just finished upgradi...
I'd like to know if WAP121 can be centrally managed by WLC, such as CT5508.If WAP121 cannot be centrally managed by WLC, is there any way to minimize operation work to manage WAP121?
Hi,I am looking into purchasing WAP121 AP product and understand it supports 802.1x RADIUS.For an intergration with NAC product from Bradford, I need to know if WAP121 supports RADIUS COA standard or at least there is a way to disassociate a client t...
HiI am having problems getting Captive Portal to work for my guest network on my WAP321. I can see two or three similar threads on this forum, but have not been able to find a solution. Let me also say that I am not a network expert, so please forgiv...
Hi guys,Could someone tell me if there is an Access point with captive portal and dhcp server?I need a device wich authenticates guest users and give an ip address.I know the controlled based solution do this but I just need an access point.Thank you...
My WAP321 connected to a office switch A.WAP321 wifi clients unable to get DHCPClients wired to switch A can recieve DHCP.Using firmware vesion 1.0.2.3I'm perplexed still.
Hi, I was reading a lot of previus discussions, but I still not understand if I can do it! I do know that "HTTP Redirect" can be used to send to external web site, but can I use it as Authentication ? If it is not possible, can I use this...
Laptop wifi connection(WAP321) Works! for the file server and internet services.However printing to specific printer(wired connected) on the network is failing. Unable to connect.Is there a 'port' configuation that I might have overlooked for the WAP...
I need to design a point to point wireless setup for a client and the locations are about 1000 feet apart. I was contemplating using 2 X AP541n access points with MIMO antennas, but can't really find any documentation on if this would work, or even ...
Hello to All,customer needs to know the following:1. can this device handle guest user access levels ?2. is there a log file available where the admin can see which users are just logged in ?3. is it possible to use a blacklist ?Many thanks in advanc...
