Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi!I used to have a DLINK router which covered my whole house with its Wifi signal. After upgrading to the SRP541W router, only the very close vicinity of the router has any acceptable level of signal to use devices. I seriously need to improve WIFI ...
Hi Guys,I have 3 ap541n's in a cluster. I have upgraded 2 of them to 2.04 firmware. The third did not take the upgrade well and hung during the process. I have tried factory reset it but to no avail. Are there any suggestions as to where I can go fro...
I have a Win7 network with a NetGear FVS336G connecting locally by wired Ethernet through a WAP2000 to laptop wireless machines. All works okay after booting a Win7 wireless machine for about 20 minutes. Then, the wireless machine loses connectivit...
Hi,I have configured two AP541N in a cluster, but only VAP0, is listed as clustered. None of the VAPs seems to be clustered. What can I configure to get all SSIDs clustered?Product Identifier:AP541N-E-K9Hardware Version:V01Software Version:AP541N-K9...
We have 3 facilities that have Cisco WAP4410Ns. Each has about 8-10 of these units. They are all running POE using Cisco POE switches. We have 2 SSIDs set up with VLANs etc. The units work fine for a random amount of time, then they seem to hang....
We have deployed 2 WAP4410N Access Point in an office environment. Both have been set using the same SSID to allow roaming between the two APs. The client has mostly Macintosh computers which only have the Airport and no LAN connection on them. The s...
I'm able to to create my main network, but unable to create guest network. Already create CP and when connected to the guest SSID, the guest could still see my main network. How to create Guest network?
Hi,I have a Cisco wireless router RV220W and a aironet 1041 access point.I configure the aironet as an repeater but the problem is that the wireless router can't see the repeater (aironet). can anybody help me with this case???many thanks,RogerBelow ...
What is difference between Ciscio Media Connctors and Access Point? Like WES610N vs WAP610N.Comparing Access Point, WAP121, WAP321 and WAP610N, which one has better wireless performance in terms of coverage and constant data transmitting speed.How to...
I recently replaced my working WRVS4400N v2 Router with an RV180W. Unfortunately I am now stymied, as I am unable to use WDS to connect my WAP4410N to the RV180W to fill a dead spot. I tried calling support (case # 623405011) but we were unable to g...
Thinking of getting a RV180W or RV220W for my home office. Setup E4200 before and other consumer models but first time to use business class (interested in VLAN support to keep home & office LAN separated for example).So question with the firewall in...
Hi,I have one L3 Switch which is connected to three L2 switches and then three WAP4410N devices are connected to L2 switch. I configured three diffrent VLANs for my users. i want to configure like this:- one VLAN for wired user, one VLAN for Wireless...
I have spent countless weekends trying to configure the WAP 4410 as a wireless repeater. From what I see the instructions and help screens seem to be incomplete or the WAP is not capable of this function even though it is available.It will not conne...
It's my intention optimize our business WiFi network.(see attachment for actual configuration)Actually we don't have a "Guest" access.Probably WAP321 should be the best solution for us.We will need 3 WAP321 to cover offices area.I have different ques...
