Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gear Support page index - Contains ...
CoreyP319 by Cisco Employee
  • 3843 Views
  • 1 replies
  • 5 Helpful votes
The documentation for the 4410N states it supports 802.1x however, all I see is to configure 802.1x using mac address or using uername and password.Does the 4410N support 802.1x using EAP? If so how is it configured? Thanks!!
xjoshx by Community Member
  • 1387 Views
  • 1 replies
Hi!I received my RV180W & started configuring it via web interface.For test purposes I have it connected to a home broadband router (10.10.7.1). I entered a static route in the RV180W which is on the 10.10.10.x. The RV180W WAN port is getting an IP i...
sideways4wrc by Community Member
  • 3161 Views
  • 2 replies
I've got a customer looking to deploy a few WAPs.  I noticed the WDS feature provides seamless roaming.  Both WAPs will be PoE based so I do not need the wireless bridge feature as it seems redundant.  What is the best way to deploy these to present ...
Hi!I used to have a DLINK router which covered my whole house with its Wifi signal. After upgrading to the SRP541W router, only the very close vicinity of the router has any acceptable level of signal to use devices. I seriously need to improve WIFI ...
svegus1651 by Community Member
  • 2361 Views
  • 3 replies
