Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 1886 Views
  • 1 replies
  • 5 Helpful votes
Hello,I have WAP4410N with firmware 2.0.4.2I want to configure it this way.1-I have this external 12db antenna connected to one of WAP4410 3x3 antenna connections PLUS the other standard 2.2-I want the WAP4410 to connect to an accessible Wifi SSID se...
Добрый день!Нужна помощь в настройке оборудования, я сам настроить не смог.Итак, я имею Linksys E3000 в качестве роутера, но его Wifi недостаточно силен и ноутбук не видит его в другом конце квартиры.Я решил использовать WAP4410N в качестве репитера,...
I have two AP541N's (running the latest firmware - v2.0.0) which I recently started monitoring via SNMP.  Everything appeared fine until I rebooted the devices and noticed that the uptime was coming back as 200+ days.  At no point in time have I been...
I have a WAP4410N-A V02 with firmware 2.0.4.2 for my office and the same at several client locations. The problem I see with all the units is that, for N-mode connections, the maximum reported connection speed is 130Mbs at both the WAP and the client...
eruth by Beginner
  • 1955 Views
  • 0 replies
