Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,I work in IT in a non-profit, we are looking to re-use a Cisco WAP581 from a location that was closed to use at another location. During the closure of the site, the mounting bracke was left I am not able to find it on eBay or Amazon, tried a g...
Hi,I've got cisco wap 581 access point and i would to mount them on the roof of my office.Do anyone know that cisco wap 581 is compatibile with Air-AP-Brackets or some other solutions? Regards and thank you.
Hello everyone, We currently run WAP371 Access points at our site, but the higher ups are interested in upgrading to something with WPA3 for our wireless. I noticed that the 571 is the replacement for our end of life product, but I can't seem to l...
I am installing a WAP321 that I'm having a tough time with getting LAN access to work. Does this device require a special cable when connecting directly to a non POE switch? I can get the device to work with a seperate power adapter and connect to m...
Hello, We are using WAP571 Wireless-AC/N Premium Dual Radio Access Point with PoEFirmware: Version : 1.1.0.3 We experience very slow wifi connection on laptop and mobile phone on specific website and vpn services.Please note that speedtest result is ...
I just upgraded my WAP125 to 1.0.3.1 and I can no longer communicate to the device using SNMP v3. SNMP v2c does work so the issue is limited to SNMP v3. If SHA/AES is used to create a new user on the WAP125 when I use those credentials I always get U...
I have two WAP150 and two WAP125 which are monitored by Zabbix.One 150 reboots periodically under Zabbix.Today I investigate and find out two consecutive SNMP request cause rebooting.Below is my test code which raise rebooting both 125 and 150.// UDP...
Hi, I will set up 3 WAP150 in Cluster mode and my question was, if one of the WAP is 100 feet away how will it communicate with the other WAP. Is the cluster info transmitted over the wired or wifi? Thank you
Hi,I'd like to drive my WAP581 by POE-injector (not Cisco) and got the famous notice "The 5G radio is disabled, due to Power Source now is insufficient (802.3af)"I have tried different cat5e/cat6 cables.I guess it depends in that the injector is not ...
I have a cluster setup of two WAP371.......below screenshots of the config. disconnects clients every few days and won't reconnect until the AP is rebooted. Log Message from AP 192.168.10.5TIME Priority Process Id Messa...
Hi,I have 2 WAP 361 devices running in a cluster and powered via PoE by a CISCO SG250-08HT switch. The dominant device boots at 6:30am. The non-dominant one boots at 7:30am. Both are set up correctly to obtain their system time from a set of reachabl...
Hi Everyone,I am new to this board and I am having trouble seeing if my Wireless Distribution System is set up properly. I have gone into each WAP571 and added the other two WAP571's mac addresses to the 5GHz network. I can manually add the MAC addre...
Hi I have the following configuration:- RV110W wireless router, central on ground floor, channel 1- WAP150 (1) wireless access point, one side of ground floor, channel 9- WAP150 (2) wireless access point, other side of ground floor, channel 12- WAP15...
I recently purchased a CBW140 and replaced an existing UniFi wireless network with it. I am very pleased with it, and I moved to disable the entire UniFi network and installed a CBW145 in wall unit to replace an existing UniFi unit. However, when plu...
Hello I have a small cluster of two WAP 371 using both 2.4 and 5 GHz band.It works fine for most devices that can connect easily, except a couple of devices:- Printers : HP 4780 and Canon Pixma 510- Gramofon- "old" PCS (a 8 year old ASUS)More over, m...
