Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
The Data Sheet on the Cisco AP 541N Wireless Access Point (features and benefits) says it includes an easy-to-follow graphical user interface to guide you through the setup of a guest network. This highly secure guest access solution lets visitors g...
Dear All.I've genereal question about pairs used to power up(using PoE) the cisco small businness APs:- WAP200- WAP2000- WAP4410nI know that all of them are 802.3af compatible, but is it also possible to power them up using passive poe injectors?If i...
Hi,hope anyone can help because it seems to be that cisco and linksys can´t. cisco support phone number is broken now for hours so i can not reach anyone thereso here is the storyi´ve made a firmware upgrade to 2.0.1.3 because of the wap200 was never...
I downloaded firmware version 2.0.1.3 upgrade and two of three WAP200 are now non-functional. I have tried the reset several times but no matter what I do all I get is the Power and Ethernet light. The Wireless light does not light at all.The first...
Dear Sir,i have a linksys by cisco wireless WRT54G router .i want to block some webside for WRT54g router ?So please help me the configuration ?
hi all, my first posting to these forums, i hope someone from cisco reads this here.currently (with fw 2.0.34), if you try to access the configuration panel of a wet200 with a browser other than firefox,opera or IE, you don't reach the control panel ...
I am trying to connect a WAP200 to a Linksys WRT300N router in repeater mode for one of our locations. At the other location that we have i am trying to connect the WAP200 to a Cisco Aironet 1100 Series AP. Is this compatable? I have done a site s...
AP541 Access Point Pro Series Q&A to share for keyword searches. First, need to confirm the maximum units in a cluster is 10 (or if not, what the max # is).Maximum # of units in a cluster is 10.Second, they mentioned adaptive RAID and want to confirm...
Hi,Where can I get the manual for SVR-200? Can someone let me know the default password for SVR-200?Thanks!Edward
I am trying to configure a client to work with a RVS4000 using QuickVPN. The client is running Windows Vista x64. I have turned the firewall (Windows builtin) on/off and entered custom rules in the advanced firewall allowing both inbound and outbou...
HiWe have extended the office and need to increase the wireless coverage currently provided by a WAP4400n.Is there a N repeater/range extender we can use?TIAAntony
Can this power injector be used to power the WAP4410 over Ethernet? I'm currently using it to power a Cisco WAP1131AG that I intend to replace with the WAP4410. The AP1131 is 10/100Mbps (CAT5). I would think the WAP4410 would be 1Gbps to because it s...
I have deployed a AP541N in our network today but am having trouble connecting a few clients.Our authentication is through a radius server, and we are having excellent functionality with most users. The one PC in question is an XP machine. I have co...
The option for wireless is greyed out during the intial run of CP express. The wireless option does not show up at all on the task menu the next time CP express is run. Also when running the CP Professional application and selecting Tools, Launch...
I currently have 2 buildings that are connected using wireless bridging between a AIR-AP1310 and a Cisco1800 with an HWIC-AP module. I would like to bring a 3 building into the picture which has line of site to the AP1310. I would like to use the S...
