Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 2572 Views
  • 1 replies
  • 5 Helpful votes
I am working on a wireless network with a WAP200E Access Point and (2) WAP200 repeatersI installed the HGA9N (external omni-antenna) on the WAP200E and it did help improve the signal quite a bit.From the same remote location (100% metal building with...
I tried to upgrade a WET200 with the latest firmware following massive problems during setup (connecting to the wireless network was hit and miss and I couldn't get any traffic between wireless and wired). Using the config I began to upload the new f...
networquk by Level 1
  • 2701 Views
  • 3 replies
Hi,I am using outdate version of firmware 1.2.8-ETSI, I only have problem with must power cycle sometimes, if we using with heavy transfer upload/download like torrent.my question, if i upgrade to latest firmware version 1.2.19 does it fix my problem...
agbnielsen by Level 1
  • 7560 Views
  • 10 replies
Hey guys,I'm having a couple of issues with the 4410N. We are currently using the 4410N's as access points for our Blackberrys to use UMA.I currently have 4410N connected, I can connect WiFi through my blackberry and the UMA works. Now, I try to ping...
I recenty bought WAP4410N Wireless-N Access Point:Firmware: 2.0.0.5It has a feature I never saw in prior Linksys WAPs I bought in the past. That feature is "Wifi Protected Setup"! I have two questions about this feature:1) What is the purpose of the ...
sean by Level 1
  • 11197 Views
  • 2 replies
