Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 2659 Views
  • 1 replies
  • 5 Helpful votes
Hi,I am using outdate version of firmware 1.2.8-ETSI, I only have problem with must power cycle sometimes, if we using with heavy transfer upload/download like torrent.my question, if i upgrade to latest firmware version 1.2.19 does it fix my problem...
agbnielsen by Level 1
  • 7621 Views
  • 10 replies
Hey guys,I'm having a couple of issues with the 4410N. We are currently using the 4410N's as access points for our Blackberrys to use UMA.I currently have 4410N connected, I can connect WiFi through my blackberry and the UMA works. Now, I try to ping...
I recenty bought WAP4410N Wireless-N Access Point:Firmware: 2.0.0.5It has a feature I never saw in prior Linksys WAPs I bought in the past. That feature is "Wifi Protected Setup"! I have two questions about this feature:1) What is the purpose of the ...
sean by Level 1
  • 11226 Views
  • 2 replies
When a wireless user accesses a Cisco wireless network controlled by the Cisco Wireless Express Mobility WLC526 controller and the controller is configured to use web authentication, the wireless user first gets a certificate warning page as seen bel...
Hello,i noticed that in vista that when you have an open wireless connection it prompts you for a code even though you dont have one set. There is a way around it but now its an extra step. there a very little options in the web interface to configur...
dennispwb by Level 1
  • 4755 Views
  • 2 replies
Hi EngineersI having difficulties in configuring the PPTP, and IPSEC Vpn.1. when configuring the PPTP using the Quick VPN Client, It always go to this way, Connecting>Activating Policy>verifying Network-from this state takes some time, and finally te...
I have three WAP-200e access points each equipped with a high gain antenna. One of them is located on the roof of one of our main buildings and is connected direct to our LAN. The other two are mounted on remote buildings about 150yards away. I have ...
I am a sys admin and have set up quite a few WAPs in my past, this one has me stumped. Setup is as follows:Motorola Surfboard Cable Modem connected to Grandstream HT-502 (VOIP phone service) router w\DHCP active. That is connected to an 8 port switch...
mediaTK88 by Level 1
  • 3074 Views
  • 2 replies
