Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Good day,I am trying to get a certificate working on a WAP371, but somehow I am unable to do so. I noticed that the WAP only accepts certs which include a key along with cert, and I also have a private CA and intermediary CA, so I am trying to chain ...
hi
we purchased three cisco aironet AIR-AP2802i-E-k9 but we are unable to access the gui. upon checking on the net i found out that its a lightweight ap. so i wanted to convert into mobility express. my current boot image is 8.2.151.0. but for ...
I have a Rv110w runing version 1.2.1.7 and when I attempt to active WDS it does not allow me to click on "Allow wireless signal to be repeated by a repeater" or the "survey" button. I have confiugred another wifi product to perform WDS with the Rv110...
Does anyone have any information on whether or not the RV325 router is vulnerable to the KRACK WPA2 exploit, and if a patch will be released? I did NOT see this router listed under Cisco's latest list of identified routers https://tools.cisco.com/sec...
I have several WAP371 (WAP371-E-K9) access points which are reporting a DE country code, but the web administration interface does not expose a way to change this. Can anyone point me in the right direction to make this change?
Scheduler is not operational for VAP 0. There is no possibility of selecting the Profile Name.
I have already done a factory reset without result.
I put the latest firmware version.the error is present on Radio 1 and 2 only on VAP 0
I maintain multiple buildings, and each building has anywhere between 1 and 4 Cisco/Linksys WAP4410N access points. The problem is that at random intervals, the access points just stop sending and receiving wireless traffic. Every day or two, I have ...
Hi, I have setup WAP4410 AP but clients connected on AP are not able to communicate or ping each other, please help how could i setup it to allow communications amongs clients on AP.
I am using AP as autonomous AP.
My new wap371 is having some problems with the wifi speed. The internet line is 300/300 mb/s, but I only get 30/30 mb/s on wifi.
-I have used the wizard for setup.
-Only 1 AP in the network.
-Firmware is updated to 1.3.0.4
-All cabled devices have...
Dear community, Several days ago, I have obtained a CISCO Aironet 1042 (AIR-LAP1042N-E-K9) access point from eBay. The seller has a 100% rating and the other customers stated the devices were working.I have now tried my hardest to get this thing runn...
Trying to reset, holding the button in for at least a minute, when I release, the device starts pinging on default IP (which I had changed, so something is happening) for about 20 seconds. Then it stops pinging, and never comes back. The device never...
I am supporting 3 sites with 12, 9 and 3 WAP371, each site they are set in single point setup.At the site with 3 devices, 2 of 3 APs once a while drop down: They are not transmitting signal anymore and I can't reach them via the rj45 network anymore....
