Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello, we are about to purchase a few WAP571. On the Online Emulator Website I can see that the WAP581 (ver.1.0.0.4) has allready the new Web GUI and I was wondering if this is planned for the WAP571 as well. The current WAP571 (ver.1.0.0.14) still...
Dear All, We have three CISCO WAP 321 Devices, which are having a same configuration. we have 192.168.0.x, 192.168.1.x,192.168.8.x networks. Device's are configured in 192.168.8.x network. 1) 2 SSID is created on each device. 2) SSID password, Chan...
Already setup the captive portal and created username and password to authenticate locally. But when I connect to Wi-Fi, captive portal authentication page appears asking for username and password but when I enter the credentials, it gives authenti...
Hello, We tried to update our Cisco SG300-10 to latest version 1.4.8.06, since then the system is completely dead, after the upload in HTTP/HTTPS mode the switch turned off all Ethernet ports (without rebooting) rendering the web console innoperent...
I've just bought a used WAP571 Access point. I have upgraded it to the latest firmware; 1.0.1.10 but FindIT is reporting a firmware upgrade is available. The suggested upgrade is version 1.0.1.9
I can't get the ACL to work on my WAP 150. Even if i just add a permit all on the ACL it still dosnt even let me get an IP address. Any ideas to what i might be doing wrong? PIC: shows the acl i have been testing with.
How i can configure a wap561 as a wifi repeater?Please.
Hello, I have cisco wap 150 device and I have configured static ip adddress on the LAN 192.168.200.1 connected the laptop directly to the access point on lan interface (192.168.200.10) and trying to ping but cannot !!! I have configured ...
Hello All, I have been asking this question within another discussion thread, which got resolved without actually answering the initial question: https://supportforums.cisco.com/t5/small-business-wireless/wap371/td-p/3089888 It has been over a ...
Hi, I'm in the process of setting up a HA pair and I' am unsure about a couple of things. We have already got a standalone 5508 and I'am currently setting up a 2nd 5508 for resilience. Both Boxes run 8.2.100.0 IOS. 1. Does the service port IP...
I have 4 WAP371 in one "Single Point Setup" Cluster. After "Cluster Firmware Upgrade" two of APs will not alive - I see APs have a connection to switch, power is up but did not respond on any IP. In dump I see only packets IP6 :: > ff02::1: HBH ICMP6...
We have just installed two units of Cisco WAP-150 access points. However, the coverage is very poor. The signal degrades to the point of not being usable from 40 feet away with a line-of-sight to the access point. The other unit is mounted in anothe...
HiI have RV110W wireless router and such configuration:VLAN1 - 192.168.0.253/255.255.255.0 - DHCP relay from internal serverVLAN3 - 192.168.1.1/255.255.255.0 - DHCP serverLAN cable is connected to LAN1 interface. WAN interface is not used as this de...
Hi,I have an issue with the WAP371 when I'm trying to download big files in the network or to stream media.After a few gigs of download (at a rate of 40-45Mb/s), the transfer goes to zero Mb/s and then I have to wait for 1-2 minutes before I can star...
We have a number of WAP371' in the company that we are trying to link to WEP Security (Bar-code scanners) When setting the 2.4GHz channel to 802.11b/g I can set the security WEPbut this does not broadcast! When setting the 2.4GHz channel to 802.11b/g...
