Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have purchased 2504 controller with 25 AP licenses along with AIR-CAP1702I-D-K9 & AIR-CAP1702I-N-K9 indoor access points and AIR-CAP1532E-D-K9 Outdoor access points. All these devices are connected with SG300-28PP switch. While connecting thes...
Please i need your assistance. We are using WAP4410N access point in our school and we did not password it. Students have been abused the internet and i want to put password on the Access point as a network administrator. I have used one the solution...
hi community
I have two WAP561 with firmware 1.2.0.2 running. One AP is running since 1 year without any problems. The second AP was installed 3 days ago and this AP has the problem which i have describe in the title.
This means everthing is fine wit...
Ok, so i've have taken the advice of many on here and will go for an AIR-AP2702i-UX-WLC.
So, with that in mind, where/how can a purchase a 12 month support for the kits?
Ive had a brief look around and its not easy to find here on the Cisco Uk webs...
I have a new 4410N access point.In trying to set it up out of the box for the first time, I have logged on to the default IP address and can see the first page asking for username and password.Using the default admin and admin I get an invalid user o...
I have our laptops, iphones disconnecting and then it takes the device a while to be able to reconnect to the access point (unless you manually disable wifi and enable it again).
Ive been trying to figure out how this would be possible but so far I h...
Hi,I installed four WAP 321 for a customer at a remote site. They are set to use a tagged VLAN 80 for management, there three additional VLANs used for SSIDs.They have latest firmware installed.LAN setting has untagged VLAN unchecked, 'Green Ethernet...
Hello Community.
I'm running two WAP321 with latest Firmware (1.0.6.2) in a cluster.
Both are connected to a SG300-10 Switch (FW: 1.4.1.3) in L3 Mode.
The Switch is connected to an RV130 Router (FW: 1.0.2.7).
The Router has Inter-VLAN-Routing enable...
Hi,Recently I've bought the WAP371 access point (European version) and updated it with the firmware 1.0.0.10.Unfortunately this device does not work properly in the frequency band of 5 GHz, in the frequency band of 2.4 GHz it seems to work fine.The i...
Our network setup uses static IP addressing behind a Linksys RV082 router (several switches connect directly to the router). Wireless access is provided via the Linksys WAP4400N hooked directly to the router.
A new wi-fi device is unable to connect ...
I have just purchased a new Aironet 2702i, and was advised to get the above controller to go with it.
I may have the opportunity to purchase a second hand, 18 month old 2504 with 5AP licences.
Would this be ok with regards to support?
I was g...
Good evening,
I have a client that currently has an Aruba IAP215 1750 ac access point installed, however, they are not happy with the coverage, and they are getting random client disconnects from, primarily, iphones (mostly 6s but with some 6).
The...
"show interfaces" reveals that my physical interfaces are stuck on VLAN 1, but I am not using VLAN 1 for anything, and my native VLAN is 11:cisco1702i#show interfaces...Dot11Radio0 is up, line protocol is up... Encapsulation 802.1Q Virtual LAN, Vlan...
I'm trying to factory reset an AIR-LAP1142N-A-K9 AP. I'm connected via console port. I tried to follow instructions of:
