Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,I'm using a WAP321 in my network, this have 2 SSIDs. The WAP321 is attached for switch Cisco WS-C3750X-24P-S with configuration port below. First SSID is Corp in corporate network, vlan 11, network 172.30.11.x/24 working normally no have proble...
We have a customer that has the RV110W router and 3 of the WAP321-A-K9 WAPs. The regular network is working great. The guest network we set up using the wizard on the WAP321-A-K9 is not letting anyone log on. The wireless in the router is disabled...
Dear Support, Please give me deatiled information about the "active clients per cluster" parameter of a WAP321 AP. Datasheet says active clients per cluster = 80, but i find a presentation where this number is 160 (attached). ???Another question is...
Hi!We have set up 6 WAP321 and the goal is to deploy W-LAN throughout the whole building. The setup for now is as follows- Each access point is connected with the same switch through LAN- Each AP has the same SSID- No wireless security (= WAP2 disabl...
Hello,I have to WAP561 in cluster. There are two SSIDs with the same name per AP. On in 2.4 the other in 5GHZ. Even when I am standing next to one of the APs, Singe Point Setup Seasons Menu says, I have only a signal about 50-60. If I stand about 10m...
The network has a Cisco 26-port switch, and 2 existing WAPs, 1 of which is an air 1040, and the other I'm not sure about but it looks like the other one. I need to add a 3rd WAP for a small room. I was going to use another cisco air 1040, but I don...
Hi, I read that the Captive Portal function on WAP devices only working on VLAN1. Captive Portal functionality is especialy common for guest vlan's, but practical nobody uses VLAN 1 as a guest VLAN. I assume that this is a bug because you can have tw...
Hello, I just got 2 WPA 321 APs and connected them to a Cisco SME300 switch. I love the management interface and features but I have major issue with the perfromance. When I test the speed over WiFi i get around 5Mbps download and maybe 7Mbps upload....
Have a total of 5 APs and every 2-3 days these devices seem to not allow clients to connect. Clients appear to associate but never authenticate. I have opened a case with Cisco (Case number in title) but want to see if anyone else is having this issu...
I have two WAP4410N access points, each running with the following information:- Wireless Network Mode: N-Only- Wireless Channel: Auto- Security Mode: WPA2-Personal (AES)- PID VID: WAP4410N-E V02- Software Version: 2.0.7.4The access points stops resp...
I have managed to get a static IP on the box. However, when I go to access it from the web interface I get the following message: "The AP is not in Flexconnect mode.". I have searched for instructions on turning on Flexconnect. However, all of th...
Hi We found that they stop responding to any clients so they cannot get IP addresses, but we can ping the devices and enter the administration page. The only solution is to reboot the AP. we replaced for a new one one week ago under warranty period, ...
Hi, so using the radius server in the UC540W works a treat if the wireless network is coming from the UC box.But if the AP541 is serving the wireless network, I cant get radius to work.I have removed all my networks from the UC box and have disable t...
Hello,I have a Cisco Wireless-N Bridge for Phone Adapters. I decided to update firmware on the device. I downloaded it from official Cisco web site download page. Then I just logged in to the device and initiated update procedure. I waited good amoun...
