Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 2118 Views
  • 1 replies
  • 5 Helpful votes
Hello All, We are facing problems with our 3 WiFi APs WAP200, they are constantly reboots, sometimes everyday.I've tried to configure Intrusion Alarm on each of these devices and found in syslogs that one error message is repeating for a big period o...
Hi,I have a WAP200E exterior accespoint which i want to configure as a wireless client bridge.So i want to connect this device to my base accespoint (Engenius enh700ext).Behind the client bridge (the WAP200E) i want to connect a small home network wi...
‎Has anybody setup an IPSec tunnel between any kind of iOS client and WRV200? I cannot seem to get the configuration right and certainly does not work over the standard IPad configuration.
    Hi,My name is Antreas,i just bought  wap4410n and i am trying to set it up as repeater of THOMSON TG585 router.i set it as Wireless Client/Repeater  with the same password and encryption of my router but with no luck.It shows that i am connected ...
antreas80 by Level 1
  • 762 Views
  • 1 replies
  I am trying to configure a Cisco RV120W wireless using RADIUS. The IAS server is Windows 2003. The wireless client can’t access the wireless.  The ISA server keeps getting this error: Event Type: Warning Event Source: IAS Event Category: None Event...
I am looking for some help configuring a Cisco WAP 561 to only allow web browsing.  Currently, I am able to configure an ACL deny specific ports.  I set the rules to deny the ports and the last rule allows everything.  This works ok, but I can only c...
smcnallie by Level 1
  • 2367 Views
  • 4 replies
