Cannot access WAP2000 configuration page at 192.168.1.245
Crash6011
I can't access the configuration page for my WAP2000 at 192.168.1.245.  The WAP2000 is connected to a Netgear RP114 router on port 1.  My wired PCs are all connected to a Netgear GS108 switch on router port 4.  I can't ping the WAP2000 from any wired PC at that address.  I can connect to the WAP2000 from a wireless adapter and it works fine with strong signal and the range I bought it for.  But- I cannot access the configuration page from any wired PC on my network (Win7 / Vista / XP) in order to secure the wireless network.
I have tried pinging the WAP2000- times out from every PC I have.  I have tried switching ports on the router, tried bypassing the router and the switch.  Nothing works.  What does work?  I bought the WAP2000 in part becasue reviews said it was "simple to configure".  So far not so much!
0 Replies 0
