CBW240AC subordinate AP Offline issue
vcisco2012
hi,
i have 8 CBW240AC (10.7.1) in a Group 1Ap workings as Primary (Master) and 7 as Subordinate APs this setup was working well from last 4 months but lately i am having issues with Subordinate APs these 7 AP are randomly  going offline /online. i check in logs which shows below error
ConfigSync: Sep 20 17:00:54.809: %LWAPP-3-MSG_SEND_ERR: spam_api.c:78668 The system is unable to send Rsync to AP 192.168.32.160 Failed, ExidCode 255, File Type: Opendns cert message to LWAPP; AP 57febe50:75dc6cd8:57feb6ec:57feb3b0:45442220:57feb6ec
*spamApTask0: Sep 20 17:00:20.509: %CAPWAP-3-CCO_ASD_LOG_ERROR: spam_lrad.c:103634 CCO ASD logging failed on AP-MAC 70:f0:96:86:2e:d4, reason: Index not found unable to delete tmp log
*spamApTask0: Sep 20 17:00:20.507: %LWAPP-3-AP_DEL: spam_lrad.c:6117 70:f0:96:87:fe:80: Entry deleted for AP: 192.168.32.168 (5272) reason : Normal Termination.
*spamReceiveTask: Sep 20 17:00:20.507: %CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:1139 70:f0:96:87:fe:80:  DTLS connection not found forAP  192.168.32.168 (5272), Controller: 192.168.33.28 (5246) send packet
*spamApTask0: Sep 20 16:59:54.275: %HREAP-3-EFFUPG_IMAGE_PRIMARY: hreap.c:9562 AP-7th_Floor is elected as Image Primary for Primary Capable APs.
*spamApTask0: Sep 20 16:59:54.274: %HREAP-3-EFFUPG_IMAGE_REPLICA: hreap.c:9516 AP-5th_Floor will get image from AP-7th_Floor.
*spamApTask0: Sep 20 16:59:53.442: %SIM-3-ARP_SND_FAIL: sim.c:1820 Unable to send ARP Request. Local MAC: 70:F0:96:86:2C:E0.Ip Addr: 28.33.168.192Interface # 1. Vlan Id: 0
*spamApTask0: Sep 20 16:59:52.339: %HREAP-3-HREAP_XML_FILE_SIZE: hreap_cfg.c:509 Hreap XML file size is: 31549 bytes.
*spamApTask0: Sep 20 16:59:43.067: %HREAP-3-EFFUPG_IMAGE_PRIMARY: hreap.c:9562 AP-7th_Floor is elected as Image Primary for Primary Capable APs.
*spamApTask0: Sep 20 16:59:43.067: %HREAP-3-EFFUPG_IMAGE_REPLICA: hreap.c:9516 AP-5th_Floor will get image from AP-7th_Floor.
*ConfigSync: Sep 20 16:59:41.770: %LWAPP-3-MSG_SEND_ERR: spam_api.c:78668 The system is unable to send Rsync to AP 192.168.32.241 Failed, ExidCode 30, File Type: Opendns cert message to LWAPP; AP 57febe50:75dc6cd8:57feb6ec:57feb3b0:45442220:57feb6ec
Anyone please Advise...
6 Replies 6
CoreyP319
I ran into a similar issue where the bridge group name did not match on the subordinate APs. Link on the topic below:
https://www.cisco.com/c/en/us/support/docs/smb/wireless/CB-Wireless-Mesh/2109-Bridge-Group-Names-on-a-Cisco-Business-Wireless-Mesh-Network.html
hi,
i followed this technote but i don't have any Mesh Option on Primary AP.
i still get below error in logs.
*ConfigSynctoAp: Sep 21 09:25:30.393: %LWAPP-3-MSG_SEND_ERR: spam_api.c:78668 The system is unable to send Rsync to AP 192.168.32.168 Failed, ExidCode 255, File Type: FindIT CA certs message to LWAPP; AP 57feb9ac:618aed20:618aea60:57feb3b0:76b94067:618aea60
*spamApTask0: Sep 21 09:25:28.790: %HREAP-3-HREAP_XML_FILE_SIZE: hreap_cfg.c:509 Hreap XML file size is: 31465 bytes.
*spamApTask0: Sep 21 09:25:20.242: %HREAP-3-EFFUPG_IMAGE_PRIMARY: hreap.c:9562 AP-1st_Floor is elected as Image Primary for Primary Capable APs.
*spamApTask0: Sep 21 09:25:20.242: %HREAP-3-EFFUPG_IMAGE_REPLICA: hreap.c:9516 AP-5th_Floor will get image from AP-1st_Floor.
*spamApTask0: Sep 21 09:25:19.497: %SIM-3-ARP_SND_FAIL: sim.c:1820 Unable to send ARP Request. Local MAC: 70:F0:96:86:2C:E0.Ip Addr: 28.33.168.192Interface # 1. Vlan Id: 0
*spamApTask0: Sep 21 09:24:59.427: %LWAPP-3-AP_DEL: spam_lrad.c:6117 70:f0:96:87:ae:c0: Entry deleted for AP: 192.168.32.175 (5272) reason : Normal Termination.
*spamReceiveTask: Sep 21 09:24:59.426: %CAPWAP-3-DTLS_CONN_ERR: capwap_ac.c:1139 70:f0:96:87:ae:c0: DTLS connection not found forAP 192.168.32.175 (5272), Controller: 192.168.33.28 (5246) send packet
*spamApTask0: Sep 21 09:24:54.280: %LWAPP-3-AP_DEL: spam_lrad.c:6117 70:f0:96:87:ed:80: Entry deleted for AP: 192.168.32.201 (5248) reason : Normal Termination.
*spamApTask0: Sep 21 09:24:25.778: %LWAPP-3-AP_DEL: spam_lrad.c:6117 70:f0:96:87:fe:80: Entry deleted for AP: 192.168.32.168 (5272) reason : Normal Termination.
*spamApTask0: Sep 21 09:24:16.109: %LWAPP-3-AP_DEL: spam_lrad.c:6117 70:f0:96:87:ed:20: Entry deleted for AP: 192.168.32.184 (5256) reason : Normal Termination.
CoreyP319
Not having a mesh option in a WLAN with subordinate APs does not sound right to me. Mesh is required for subordination, unless setting each as a single primary WLAN. Can you share a screenshot of the screen where the mesh option should be available?
vcisco2012
hi,
Sorry for confusion. All the APs in the network have a Wired Uplink. The APs in the network are Primary capable. One among them is serving  as a Primary AP.
No worries. In the screenshot titled wifi.png, if you click the action button to the left of each AP, you'll be able to view the bridge group name. Ensuring they were all the same, solved the issue I was experiencing.
Here is a more general troubleshooting document, though it doesn't reference your symptoms exactly:
https://www.cisco.com/c/en/us/support/docs/smb/wireless/CB-Wireless-Mesh/2109-tz-troubleshooting-CBW-Mesh-Network.html
vcisco2012
hi,
Please check attached Screenshot  of one of the AP  i don't have bridge Group option.
i am using 10.7.1.  firmware..
thanks..
