Hello.
I have a very simple question regarding the aforementioned device which I know very well it's no longer being supported / EOL. Bear with me while I explain the situation:
Currently it has HTTPS enabled and works as intended. To my knowledge, this is a self signed certificate that is created when you enable HTTPS on the device, the current certificate expires on 01/08/2026.
Is this the only certificate that can be used with this particular device? Self signed from the own device. I know it's unlikely it will expire before we get around to upgrade all of our AP's but was just wondering if this is the way it should be as I cannot find any documentation on certificate renewal or to install, let's say a wild card certificate.
I appreciate your time and help on this issue.
Regards.
Mario.
