Cisco Business 140AC: Association rejected Android 10 Xiaomi Mi9
LobbianiLAB
Beginner
Beginner
i recently bought some Cisco Business AP 140ac as a good solution for small offices.
After zero provisioning, AP (master) is working good, and i was trying performance with default config.
I found that my Xiaomi Mi9 can't connect. Using android debug, it says
NETWORK_SELECTION_DISABLED_ASSOCIATION_REJECTED = 5
I checked password and auth mode (WPA2 PSK), everything is k. I can connect computer and other mobiles, but this xiaomi is rejected.
There are no special mac address policy, or something like this. Android version is latest 10, MIUI 12.0.1
I have no problem connecting to other AIR-CAP3702
AP log was not useful (for me)
How is it possible that this device isn't accepted by AP?
Thank you
Martin Aleksandrov
@LobbianiLAB
Please open up a case with the STAC technical support center and you'll be further assisted from one of our network engineers. Contact details are as follows:
web case creation link:
https://mycase.cloudapps.cisco.com/case
STAC contact details:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Martin
Recognize Your Peers
