Cisco RV220W and Cisco Aironet 1041
rdelacroix
I have a Cisco wireless router RV220W and a aironet 1041 access point.
I configure the aironet as an repeater but the problem is that the wireless router can't see the repeater (aironet). can anybody help me with this case???
many thanks,
Roger
Below you find the config file of the aironet configuration.
Current configuration : 1250 bytes
version 12.4
no service pad
service password-encryption
hostname APCR2
logging rate-limit console 9
enable secret 5 $1$Ipk6$24lXe.WDBKxeONLPKNPZv.
no aaa new-model
dot11 syslog
dot11 ssid FENL01
   infrastructure-ssid
username Cisco password 7 047802150C2E
username rdelacroix privilege 15 secret 5 $1$yE.c$RyGiK9NkxIRNPcp5aBqxX1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
ssid FENL01
antenna gain 0
parent 1 70ca.9b9a.30f0
station-role repeater
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Stephen Stone
no ip address
no ip route-cache
shutdown
Need to enable the radio
jurodri3
Hello  Mr.  De la Croix,
Thank you for your question.
However, the Small Business Support Community is limited to Cisco Small Business Products, and the Aironet products are considered as a Enterprise level devices.
I recommend you to post this question on the on the correct forum, in order to get a better response.
You can move your post using the Actions panel on the right.
Best regards,
Diego Rodriguez
Cisco Small Business Community Engineer
This is unsupported,  the RV220W supports WDS repeating which means the wireless chipsets need to match up.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
