Cisco WAP581 brackets
Vicebal
I've got cisco wap 581 access point and i would to mount them on the roof of my office.
Do anyone know that cisco wap 581 is compatibile with Air-AP-Brackets or some other solutions?
Regards and thank you.
psandel
Hi Sir,
My name is Puneet Sandel and I am from Cisco small business technical support center.
Thank you for becoming a part of Cisco family. I will like to tell you that you can only use wall mounting kit that you would have received in the package contents of the wireless AP.
Any other brackets may or may not be compatible with the WAP581.
Puneet Sandel
Technical Consulting Engineer-Level 2
Global CX Centers – Small Business Support
Does Cisco not provide replacement items for be able to re-use the technology? Looks like a lot of e-waste if someone cannot easily purchase something to help keep the tech from being thrown out.
I am looking for a replacement mounting kit for a WAP581. Location was closed, mounting kit was left behind.
