I would like to configure a RV110W device to connect to a wifi, rather than be the wifi controller. The reasonning is that I need to connect some LAN devices which will then use the wifi to connect back to mainframe etc. I dont want to use wireless card as I need to firewall the devices.
Any suggestions or help appreciated.
regards,
Chris.
