Showing results forĀ
Search instead forĀ
Did you mean:Ā
Connectors RP-SMA
Yogesh Vashisht
Hi all,
I am new to outdoor AP world please suggest....
If outdoor AP have Six RP-SMA connector then how many external antenna can  be connected with this.
Thanks in advance.
Scott Fella
Typically is you have six, that would mean 6 antennas. Some AP's have dual band antenna ports but not 6, usually up to 3. Some AP's allow you to choose what ports you want to use, but it depends on the AP.
-Scott
I might also add, depending on the AP there could be two radios, 2.4 and 5 Ghz. Typically 3 antennas for 2.4 and 3 for 5 Ghz.
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
Wireless Subject Matter Expert
CCNA, CCNA-Wireless
866-606-1866
Mon - Fri 09:30 - 18:30 (UTC - 05:00)
*Please rate the Post so other will know when an answer has been found.
